drag link flip kit
#23
#24
Sounds like it's not tight enough. Best thing is to get a very large pry bar and put down pressure on the joint so it doesn't move when you tighten it. Hitting it with a BFG, will only "press fit" is slightly, but when you start to tighten it up, it'll move again. You need constant downward force on the joint as you tighten the bolt. I had the same problem when I installed my Teraflex, I finally switched to synergy
#25
