drag link flip kit
Old 01-22-2014, 01:57 PM
13commandojk's Avatar
Default drag link flip kit
So im stumped.. i installed a drag link flip kit. Install was easy/straight forward. However the nut will not stay tight on the ball joint... i thought maybe it was a defect in the threading so i got another one and the same issue. Anyone have this problem?
Old 01-22-2014, 02:17 PM
TURTLECON's Avatar
What brand? My buddy cross threaded his by accident and got a replacement. Are you able to get the cotter pin lined up and through it?
Old 01-22-2014, 03:03 PM
D_engel's Avatar
is the tapered pin fully seated in the knuckle adapter? If its no fully seated, the pin will rotate and you will never get the nut properly tightened. You also need to use a cotter pin on the castle nut to keep it from backing off
Old 01-22-2014, 03:34 PM
theres no spot for a cotter pin. And i have the tapered sleeve set in but its stlll gets loose after driving/turning
Old 01-22-2014, 03:54 PM
Monte417's Avatar
No cotter pin hole? which draglink and tie rod end are you using?
Old 01-22-2014, 04:24 PM
rough country
Old 01-22-2014, 04:52 PM
TheDirtman's Avatar
Yet another win for rough country.
Old 01-22-2014, 05:00 PM
karls's Avatar
Safety is overrated Dirtman, those cotter keys just add extra weight and throw off the balance of the tires haha.
Sigh RC, sigh. Please higher engineers asap.
Old 01-22-2014, 05:05 PM
Maertz's Avatar
Loctite???
Old 01-22-2014, 05:16 PM
karls's Avatar
^^ or a jam nut or a tack weld.
Quick Reply: drag link flip kit
