Drag Link Flip kit
Old 05-16-2013, 11:39 AM
  #41
Flexer07's Avatar
Originally Posted by ronin2120
Go to project JK there is a really detailed / labeled picture of the components on the Jeep. Use this to ID the parts and compare with pics from here or the internet. I'm sure someone will be way more detailed then me.
Thanks man
Old 05-16-2013, 11:44 AM
  #42
ronin2120's Avatar
look under "write ups" and then click on "front end alignment". I'm not computer smart or I'd figure out how to paste it or something.
Old 05-16-2013, 01:06 PM
  #43
havochaos's Avatar
Originally Posted by Flexer07
I got my jeep already lifted so how do I tell if I have one
This is a flipped drag link. It is over the steering knuckle instead of below it.
Old 05-16-2013, 03:30 PM
  #44
RubiconGeoff's Avatar
Reid Racing knuckles come predrilled for the drag link flip.
Old 05-17-2013, 02:39 AM
  #45
ChesterJFK's Avatar
Yeah they are sweet! Tie rod mounts are also alot higher with those... Oh some day lol
Old 05-17-2013, 06:07 AM
  #46
JKred's Avatar
Be careful with Reid's. if you are running a straight drag link (like the RK) you don't have a lot of space due to the raised tie rod to run a relocated steering stabilizer or hydro assist ram, and may have to run a custom bracket off the diver side to clear everything.
Old 05-17-2013, 06:10 AM
  #47
ChesterJFK's Avatar
Synergy tie rod should work fine with Reid's knuckles though.
Old 05-17-2013, 06:16 AM
  #48
JKred's Avatar
Any tie rod/drag link combo will work with the Reid's, it's just a clearance issue. The synergy is bent so it doesn't create an issue. The RK or any made from straight DOM (like mine) isn't. Doesn't mean it won't work, just need to be a little creative.
Old 07-11-2013, 06:12 PM
  #49
What if I were to take off my lift kit and go back to stock and leave my drag link flip kit what will happened?
Old 07-11-2013, 06:42 PM
  #50
nthinuf's Avatar
Interesting. Not sure what would happen with negative angles. (maybe negative isn't the proper term, backwards steep?)
They start roughly parallel and flat. After lifting they are parallel and at steeper angles. Flip to raise them both on the passenger side and get them flat again. Remove the lift and now they are steep again, but the opposite way. Same behavior as not having the high steer/flip?
Quick Reply: Drag Link Flip kit
