Drag Link Flip kit
#21
#22
#23
Sponsoring Manufacturer
The other bar braces the drop bracket, this prevents it from tearing/damaging where it mounts. Also it's stiffens the frame up in the front. There is a bracket that needs to be welded on the passenger side of the frame for the brace bar to bolt into. These can be used in a 3"/4" or taller lift.
#24
Bumping. What did you go with Aaron?
I'm about to purchase one of the kits also. Not sure if I'm going to go with Evo, Synergy, RK.
I have the Synergy tie rod and really like it. I like the price on the Evo so far.
#25
I'm about to purchase the synergy. Looks the best from what I can see. Also they have the tie rod kit which ill purchase next.
#26
I'm using the Rubicon Express Drag Link and it's great. Then a Ruff Stuff 1.5" Tie Rod with GM 1 Ton offset ends. It's beefy and easily adjustable.
Sent from my NOTE II on Sprint using JK-Forum
#27
Former Vendor
The Synergy kit is an excellent option. PM us if you would like any pricing on this kit. The Synergy tie rod is also an excellent upgrade since the stock tie rod can easily bend.
#28
I will probably deal with Northridge4x4 in Canada as they offer free shopping, and I don't have to deal with import and brokerage fees.
#29
#30
I've went with the Synergy Tie rod and Drag link, great product really happy with it especially the tie rod. Install on the drag link is easy just need that 13/16's drill bit for the knuckle.
