Drag Link Flip kit
Old 04-03-2013, 09:13 AM
  #21
kjeeper10's Avatar
Originally Posted by aaronstephen
The Synergy kit looks like a pain in the a$$ to install compared to the evo kit. Is it really worth the extra pain of install to go with this particular kit?
There's no difference.
Old 04-03-2013, 09:29 AM
  #22
rinkishJK's Avatar
Originally Posted by kny21
Not a jam nut. Synergy uses threaded sleeves with a pinch bolt. That way you can adjust without disco'ing the tie rod end.
Ah ok I'm not familiar with there products and it looked loose. Just trying to prevent an accident.
Old 04-03-2013, 09:35 AM
  #23
Sponsoring Manufacturer
TeraFlex's Avatar
With the Teraflex one what is the other bar in the kit? Also, why is there a need to weld with this one?
The other bar braces the drop bracket, this prevents it from tearing/damaging where it mounts. Also it's stiffens the frame up in the front. There is a bracket that needs to be welded on the passenger side of the frame for the brace bar to bolt into. These can be used in a 3"/4" or taller lift.
Old 05-14-2013, 01:00 PM
  #24
suicideking's Avatar
Bumping. What did you go with Aaron?
I'm about to purchase one of the kits also. Not sure if I'm going to go with Evo, Synergy, RK.
I have the Synergy tie rod and really like it. I like the price on the Evo so far.
Old 05-14-2013, 06:18 PM
  #25
ChesterJFK's Avatar
I'm about to purchase the synergy. Looks the best from what I can see. Also they have the tie rod kit which ill purchase next.
Old 05-14-2013, 06:36 PM
  #26
BlueBeast's Avatar
I'm using the Rubicon Express Drag Link and it's great. Then a Ruff Stuff 1.5" Tie Rod with GM 1 Ton offset ends. It's beefy and easily adjustable.
Sent from my NOTE II on Sprint using JK-Forum
Old 05-14-2013, 06:46 PM
  #27
Former Vendor
Smashboogie 4x4's Avatar
The Synergy kit is an excellent option. PM us if you would like any pricing on this kit. The Synergy tie rod is also an excellent upgrade since the stock tie rod can easily bend.
Old 05-14-2013, 07:12 PM
  #28
ChesterJFK's Avatar
I will probably deal with Northridge4x4 in Canada as they offer free shopping, and I don't have to deal with import and brokerage fees.
Old 05-15-2013, 12:38 PM
  #29
Thanks guys! I'm going to order the Synergy. That's what my mod shop recommended too.
Old 05-15-2013, 12:46 PM
  #30
ronin2120's Avatar
I've went with the Synergy Tie rod and Drag link, great product really happy with it especially the tie rod. Install on the drag link is easy just need that 13/16's drill bit for the knuckle.
Quick Reply: Drag Link Flip kit
