double throw down front with bolt on coilovers in the rear????
looking into going to coilovers. i know that there are a million threads floating around about this, but i have not seen this combination mentioned.
Would pairing the double throwdown in the front, with the bolt on rear coil over system be an effective combination?
Thanks in advance!
Thanks in advance!
I'm not a pro with this but I have been down to evo a bunch and am currently waiting for parts to arrive and they will be insatlling my coilover setup. I think that the dtd setup in the front will be awesome. but if you only go with the bolt on setup in the rear it will fall short. u will not be able to fully enjoy the benefits of having the additional bypass shocks up front with only the coilover in the rear. for the fast stuff the front with be sucking it up but the rear will bottom out and not be able to keep up.. in other words, you will have the sickest setup in the front that is totally limited by the rear. i mean, it will def work but you are really gonna want the extra bypass shocks in the other two corners. if u go with the bolt ons in the rear and decide you want the dtd in the rear(which i'm betting is what will happen), you will need to totally swap the rear setup for the lever dtd.
if you want the dtd in front, do the evo lever dtd kit in the rear as well but just use the coilovers for now. you can always do the dtd kits in front and rear but just add the bypasses later. this will save you on the initial bill but you will be ready to bolt on some bypasses once you have more money. this will also keep you on the "do it right the first time" path. you will have the coilovers you want, with the option of adding bypasses. call and talk to Jake at Evo, he can give you the best advice for what you are thinking!!
Thanks in advance!
Thanks in advance!
prob want to stick to evo spec stuff on all four corners at that price level to ensure the valving/spring rates play nice together
Sponsoring Vendor
Thanks in advance!
Thanks in advance!
That way he can upgrade to the bypass shock when he's ready upgrade to the cantilever in the rear. Eitherway you want to run it, its far superior than any other coilover system on the market.
Sponsoring Vendor
Most customers go with a double throw down tower in the front with a coilover, then run bolt on coilovers or just coils and shocks in the rear. In order to save money and If you plan on upgrading in the future to the double throwdown system...
just food for thought
assuming you are talking about running the single EVOlever system (no bypass shock). The rear can not be upgraded to make it a double throw down (bypass shock and coilover). You must replace the subframe, arms, hardware etc.
