Door stuck?
Door stuck?
This is really strange problem. I remove this screws at the bottom of the doors all the doors came off but the passenger rear door will not come out of the hinges. Any ideas?
It was the first time I have had the doors off since five and the vehicle. Turns out that my neighbor who owns a TJ came over and showed me where the hinge was pinching for some reason or another.
I was trying to take the door off with it all the way open however he lifted it where it was closer to being closed.
Thank you for the input. I will add some grease to it when I put them back on after this weekend.
I had the same problem the first time I took all my doors off. At least for me some break free worked. When I out them back on I lubed them really well which may or may not help (I haven't taken them off for nearly two years now so I don't know if I'll have a problem when I do).
Had same issue last year trying to get my doors off, except it was all of them. Used the jack method and once off changed out all the door liners with TMR Customs Derlin inserts. Come off so easy now, definitely worth it.
