Doing research to pick a winch...how high a weight limit?
Would suggest not going too big on the winch. 9000-9500 is fine (even if you drive a two door, you might be pulling out your buddy's four door, LOL). More powerful pull winches usually have a couple disadvantages: Slower (more gearing) and shorter line (thicker and stronger, but less fits on spool).
I just got this one for $350 shipped. Engo e10000. Now we have to try and fit it into the AEV bumper with the winch plate AEV makes. We'll see how it goes.
I'm a Warn fan myself and run an M8000 but I think one of the best values out there is the Smittybuilt XRC10 comp. real nice price, 10k load, reasonable line speed and syn line.
You can't go wrong with a Warn. I've never owned a new one, but I have had several used Warn winches and have never been let down by one. I've owned two of the old Belleview type 5687's, an 8274 and recently an M8000 on the JK. They've all been great and Warn has helped me out piecing together the older winches. I prefer the 8274 for heavy duty off road duties, so it's on the CJ. Another great thing with the Warn is that they're easy to sell when you no longer need them. Warn has great name recognition, plus I personally like that the premium series is still made right down the river.
Keep in mind that the Zeon model wont fit some bumpers, namely some of the bumpers that have a sunken winch mount. The drum on a Zeon winch is centered, where as the drum on most other winches is offset. So if the slot in the bumper for the winch cable is offset, the Zeon winch wont line up right.
The Warn 9.5 xp is a good winch. It has a higher output motor (6 hp) and faster line speed than most other winches.
The Warn 9.5 cti-s is a good winch as well. It is compact for a winch with an integrated solenoid, and only weighs 66 lbs. A Zeon 10-s weighs 75 lbs.
The Warn M8000-s is also a good winch. It is compact, easy to mount in close spaces, and only weighs 55 lbs.
I have the Ace mid width front bumper and the is a structural change so the winch position does have its limits...
At this point it's either going to be the Warn V8000-s or the Warn V10000-s
Unless I find out it won't fit or somebody had a really good idea that causes me to rethink...
The dead lifting a tj kind of sold me!
The price difference between the 8k and the 10k is only $100
So unless I'm missing something that's a lot more lift for a fairly small price bump...
The only thing I read that made me stop and think about it was that I probably need to get a stronger battery?
That the stock one is only 600 cold cranking amps, and that the winch needed a minimum of 660 cca?
Is that someone's opinion or a widely accepted fact??
Anything else for a first time winch buyer? Any downsides to going with synthetic line, or any down sides on getting 2k more pulling power?
Matthew
Sent from my iPad using JK-Forum
Matthew
Matthew
Synthetic is great, just make sure it doesn't get chafed over inanimate objects like rocks and trees. Also, keep it covered from the sun and other elements when not in use.
