Does Anybody here have a Device to Turn of My ESP? (Los Angeles)
#21
#22
The solutions provided to you, namely, fix your off centered steering wheel will literally take 10 minutes. In the time you've made all the posts asking how to disable it completely you could've gone outside and fixed the issue completely.
#23
Former Vendor
The easiest thing to do if you want it off all the time is remove fuse J6. It is the ABS pump fuse and that will disable ESP completely. You will have the Traction Control Light and ABS light on your dash. If you want to turn it back on just plug the fuse back in.
#24
#25
Former Vendor
#26
Jeez almighty. Just center the steering wheel and be done with it. You dont have to shut off the system, its working as intended. It thinks you are in a skid because your wheel isnt straight.
#27
I worked on the steering today, its dead centered and the eps is still coming on every turn. I'm going to pull that fuse for now. I'm really disappointed in the dumbasses at Jeep for even including this with no option to turn it off. FAIL.
#29
Former Vendor
