Does a 2.5" BB REQUIRE disco's?
Have ordered everything except disco's and wasn't really sure if I needed to buy them or not... The lift is a spacer lift.
The stock sway bary links are really short and having just gone thru this myself with a 2"BB, I got the longer links. TF sells a set for 0-3" boosts that worked well. From what Ive read here, if you dont use them and you go wheeling, you take a chance of flipping the links and doing damage to the tie rod. If you got the TF 2.5" BB it should come with the extended links for the rear. You then reuse the rear stock links in the front.
VT
VT
