Dodge Ram 1500 diff/tubes/axle swap?
Old 10-10-2011, 12:00 PM
junk's Avatar
Default Dodge Ram 1500 diff/tubes/axle swap?
Preface: This question is 100% fishing expedition as I've done no actual research into the matter.
I have a '99 Dodge Ram 1500 4x4 that I feel is near the end of her life. She has almost 200k miles on the 360 and she's tired. Rather than just send her to a scrapper, I was thinking I could pull some parts and toss them in some other vehicles. How feasible would it be to take the diffs/axle tubes/axles from the Ram and put them in the (2009) JK?
As the proud owner of an el-cheapo X model, I could really use something better in the front and, if I'm going to do it anyway, I might as well swap the rear. Would it be worth it to swap the D60/D44 setup in place of the D44/D30? How much of a pain in the ass would it be?
Old 10-10-2011, 01:42 PM
junk's Avatar
It would be worth the strength but you may have to weld on new perches and mounts for everything, also think about your driveshaft and the speed sensors that we have.
Can you explain your thoughts on the speed sensor? The quick searches I did on the subject indicate that the speed sensors are in the wheels. Is there something else you have in mind?
Regarding the perches, I figured I'd have to do that. I may have to shorten the axle tubes as well, since I'll want it to be a driver an CA law takes issue with wheels that stick out without being covered.
Old 10-10-2011, 02:24 PM
jesse0376's Avatar
I live in cali and have run full width under my yj. I would leave them stock width and throw some mud flaps on.
Old 10-10-2011, 03:10 PM
Delux2769's Avatar
That would be a great swap, especially for us poor 2WD jeepers.
Old 10-11-2011, 01:26 PM
junk's Avatar
Speed sensors are at the end of the axleshafts. In the pic below you can see the gear, that is key to the speed system.
Aha! Seeing it makes a ton more sense. I was thinking it was more of an electronic thing than a mechanical issue. Thanks for cluing me in.
I'll have to crawl under the rigs and see what the dimensions look like.
Old 10-11-2011, 02:43 PM
SilverBolt's Avatar
It is an electronic thing. The gear looking device is one piece of the puzzle. It's the tone ring that the sensor reads. It's not a gear.
Old 10-11-2011, 03:53 PM
WXman's Avatar
You've got a 1500 with a D60 rear? I thought the Rams got D44s front/rear or the Chrysler 9.25 rear?
Old 10-11-2011, 06:36 PM
junk's Avatar
I'll double check but I'm pretty sure the build sheet says D60. I'm positive it's not a D44.
Old 10-23-2011, 06:39 PM
Mark's Avatar
bump bump bump
Old 10-23-2011, 07:40 PM
08JKRHD's Avatar
I wanna know if this works! My grandpa has a 1500 I could rob axles from....
Quick Reply: Dodge Ram 1500 diff/tubes/axle swap?
