Do you have Rugged Ridge Rocker light Switch?
I just installed two of Rugged Ridge Rocker light Switches for the D2s and Ebar. The lights on these are ALWAYS on, even when there is no key in the ignition and the switch in OFF position
. Is that normal? Would it not drain the battery in a day or two?
![Thinking](https://www.jk-forum.com/forums/images/smilies/thinking.gif)
Just reverse the power in power out wires on the switch connectors.
Last time I tried reversing wires on the switch, I blew off the fuse on the both D2 and Ebar. Rigid Industries wiring comes with three wires - black, blue, red. According to the Rigid schematics Black wire goes to the "golden" pin - the one that stays bit away from other two, blue wire goes to the middle pin and red to the last third pin. Which of these wires I should switch to which pins?
Thank you!
Thank you!
Thank you!
I have daystar switches and I had to switch the wires around so mine didn't stay lit all the time to......
