Do these 2dr Shrockworks Rock Rails look right?
Old 11-24-2008, 04:23 PM
  #21
doc307's Avatar
Jk-Rubi, rails look great. It's too bad you did not post these pics earlier. I would have saved some money. I ended up getting my rails and pinch Rhino lined.
Old 11-27-2008, 07:58 PM
  #22
BIGJ's Avatar
that look real good, i like the pinch seams cant wait to do it to my rig soon
your rig is looking awesome
Old 11-27-2008, 08:08 PM
  #23
robin's Avatar
those look good...... good job!!!!!!!
Old 11-27-2008, 10:45 PM
  #24
SilverSaharaJK's Avatar
Looks great!
Old 11-28-2008, 04:34 AM
  #25
JK-Rubi's Avatar
Thanks for the comments. Here's another pic of the pinch seam, and the new bolt hole locations in the frame. These rails are on solid!!
Old 12-07-2008, 05:37 AM
  #26
JK-Rubi's Avatar
Default Sliders out on the Trail
Just a couple shots of the sliders mounted and outside playing :
With other forum members on a recent ride.
I wasn't planning on using them as steps, but in the below pic, without them, I'm not sure how I would have been able to climb back into the JK (because of the angle, my feet were on the ground next to my rear tire). I guess I would have gotten in, but it wouldn't have been pretty.
Old 12-19-2008, 05:15 AM
  #27
Skippman's Avatar
That looks amazing! I'll definatly be doing that to the Rubi's rock rails.
Old 12-19-2008, 07:06 AM
  #28
northsidejeepin's Avatar
Beautiful work. Looks professional to me!
Old 12-19-2008, 11:23 AM
  #29
JK-Rubi's Avatar
Thanks for the compliments. Prior to spraying my rails, I'd never used this stuff before. I'm not as adventurous as many on this forum (nor as mechanically inclined) so you can rest assured that if I'm able to achieve the pictured results, then this product is easy to use with little proficiency. Just make sure to prep properly, and take your time (repeat the latter 5 times). Don't try to cover everything on the first pass, and let it dry say 20-25 minutes between applications.
For more info on application, see this thread ---> https://www.jk-forum.com/forums/jk-show-tell-33/steel-blue-w-bedlinered-grill-51763/, and particularly note JKrazed's comments!!
Old 01-27-2012, 05:21 PM
  #30
mark9998's Avatar
Im gonna do this to my JCR rails this spring, how has yours held up since you did it in 2008 it looks like? Im assuming you probably need to touch them up from time to time especially if you do alot of wheelin?
Quick Reply: Do these 2dr Shrockworks Rock Rails look right?
