Do lifts level?
I want to just level my '11 JK for now until I decide on a lift and tires. I was just wondering if most lifts around 2.5" level out the factory rake or if front spacers are also needed.
Spacers will level it out, but I'd start by checking what size coils you have in the front... I had 17's and bumped up to Rubi coils (18's) and it leveled out my front end...
Most lifts do tend to level and in any event the rake looks different when the jeep is lifted. Unless you know someone with the same lift, I'd install the lift first and see how it settles, then decide on spacers. IMO, overcorrecting the rake looks worse than leaving it in place.
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
![](https://www.jk-forum.com/forums/images/ranks/veteran_air_force.png)
Assuming that you're pretty much stock (no heavy bumpers, winch, etc), then most 2.5" budget boosts will do the job. They typically use a 2.5" spacer up front and a 2" spacer in the rear to remove the rake. When you add heavy mod's, that can shift around and you may find that you need to replace the stock springs with something a bit beefier. TF also has a leveling kit that adds just enough lift to the front and rear to level things out without adding a lot of lift. I just helped install one the other day and the level of work is essentially identical whether you chose their leveling kit or their 2.5" BB. So, if you think you might go to 33 or even 35" tires, you probably should just put the 2.5" BB on. Hope that helps!
