Do i need wheel spacers
Old 10-12-2019, 04:40 AM
Juweinat1's Avatar
Default Do i need wheel spacers
I just installed a 2inch lift & wonder if I need wheel spacers to run 33.8 inch 285 75r17 tyres?
Old 10-12-2019, 07:05 AM
TheDirtman's Avatar
Yes you should be looking at wheel adapters if you are doing more then driving on the road.
Old 10-12-2019, 10:58 AM
Juweinat1's Avatar
1 or 1.5 inches?
Old 10-12-2019, 12:49 PM
nthinuf's Avatar
Originally Posted by Juweinat1
1 or 1.5 inches?
1.5" - 2" is the popular range. You want the type with two sets of bolts, not the thin ones that sandwich in-between and leave the lugnuts fewer threads to grab onto. Of that style, 1.25" is the narrowest that I have seen (Teraflex), but they caution that being that narrow, the lugs may need to be trimmed a bit. So go for 1.5", like the SpiderTrax.
Another option that some folks try is to add a washer or two to the steer stops - if the rubbing is minor.
Old 10-12-2019, 01:13 PM
Juweinat1's Avatar
Thanks!
Are these any good or no? This shop is local to me and I can get them much quicker I believe otherwise spiderTrax it is
https://bsawheels.com.au/shop/access...rs-with-bolts/
Old 10-12-2019, 07:18 PM
resharp001's Avatar
Received 1,944 Likes on 1,701 Posts
I'd highly suggest not to go with those. Spidertrax or Synergy.
Old 10-13-2019, 03:24 AM
jadmt's Avatar
I disagree those look high quality, I’m pretty sure they have a great reputation in Australia similar what BORA has here.
Old 10-13-2019, 06:29 AM
nthinuf's Avatar
My take on it is that, other than sending them off for a metallurgical analysis yourself, there really isn't any way you can know for sure.
Posts 9 and 38 in this thread have reports from forum members on two other brands.
https://www.jk-forum.com/forums/modi...safety-130315/
Here in the states, Spidertrax has a good reputation, and the analysis that was reported in that thread seems to back up the quality. Down in Australia, BSA could have just as good of a rep and we don't hear the name. I guess the moral of the story was noted in post 38. Just because a manufacturer talks up their own products and lists a certain quality of material, doesn't necessarily mean it meets that standard.
(And as was brought up in a few previous posts on the subject, just because a quality spacer was bought, doesn't mean that it was actually installed correctly, or that the owner didn't forget about them and they loosened up later. Just a friendly reminder to not forget they are installed...)
Old 10-13-2019, 07:35 AM
resharp001's Avatar
All good points by nthinuf.
I keep forgetting OP is international and has different obstacles to overcome in regard to availability. Doesn't change my opinion, but I understand the questioning.
Old 10-13-2019, 03:19 PM
nthinuf's Avatar
I'm with you on this. For many things, lesser quality (or unknown quality) may work perfectly fine, and if the product turns out to be sub-par, it may just be an annoyance. But for other things, like a tire coming off at freeway speeds because the company was looking to save a buck? That doesn't quite fall into the same category for me. (the inferior grade bolts being passed off as 'quality' from the linked thread is a good example here.) I could very well be over-thinking it, but I went for what I saw as a better quality product with spidertrax.
Quick Reply: Do i need wheel spacers
