Do I "need" rear upper control arms for 2.5"
#21
Is there a way to measure if everything is in the right spots? Such as with lower CA, is there a caster you should be trying to achieve and when you can't get it, then get the lca? Or the driveshafts? Is there a way to measure them being centered so you know you need a track bar?
I have the TF 2.5 spring lift with Rancho 9000, and it rides fantastic. But being a newb, it would be nice to see if everything is in spec and could/could not be improved by lca or track bar.
