Do I Need Extended Bump Stops??
OK, I've been searching the forum and I THINK I found the answer but I wanna be sure. Right now I've got 2.5" of lift in the front with shock extensions.
On 32" tires, am I in danger of compressing the front shocks too much when flexed? I'm hoping for an answer like "nah, you'll be fine...don't worry about it." because it's already done and I don't really wanna take it all apart again if I don't have to..
![crazyeyes](https://www.jk-forum.com/forums/images/smilies/crazyeyes.gif)
My measurements on my stock Rubi JK 4Dr found that the stock shock compressed length is only about 1/4 inch shorter than short enough. I considered bump stop squish, so give or take a 1/4 inch.
If you made your stock shock's compressed length longer using extensions you need bump stop extensions or a new longer bump stop.
![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
OK, I got em installed today.....a buddy of mine had some that he took off his GMC truck, they're about 3" tall (after I trimmed a bit off).....hopefully they'll be alright:
![](http://i108.photobucket.com/albums/n35/06liberty/Other%20Stuff/IMG_1300.jpg)
![](http://i108.photobucket.com/albums/n35/06liberty/Other%20Stuff/IMG_1301.jpg)
I originally had a 2 inch bb with 33 inch tires, and a sway bar disconnect. At full stuff or big bounces on tough trails I rubbed pretty bad on the fender flares. I was too lazy to install the new bump stops that came with the BB.
When I installed my 4 inch springs, I went ahead and installed the extended bump stops that came with the 2 inch bb, and voala! No more rub! It was about twice as long as stock, and was hard neoprene rather than the soft rubber, so it was a pita to get in, but gotterdun!
