Do I need to cut Rubi Rails????
Maybe its just like that on the new models but your rail seems to hang pretty darn far back. My Rubicon is an 08 and it pretty much stops at the edge of the flare, yours looks like it goes beyond it, and into the wheel well a few inches which does not make sense??
Just cut it and recap it.
If you want an idea of what it would look like lifted jack up the back of the Jeep (On the body, hitch is a good spot if you have one) Extending the suspension a couple inches, You can probably get 2-3 inches before the wheel comes off the ground.
Lucas
Lucas
I saw the write up on that, and it seems if I cut the rail, I will have to cut the pinch seam, otherwise it will be seen behind the rail. And I really don't want to cut the body of my Jeep
I apologize if I annoyed you with my question, response, or unwillingness to hack my Jeep up, but I thought that what this forum is about to help people out when they don't know, undecisive , or unsure about something.
And you can do this : All day long.
I would pull the rails off the jeep and even just with a hack saw I would cut about an inch off the ends, the little black plastic cap pops off and then you can put it back on and you wouldn't even notice it, no one would. You don't need to touch the pinch seam it will look fine
Flexing isn't a complete test. If you flex 35s you'll see that they don't contact the pinch seam. However, if you get out on the trail, 35s do contact the pinch seam (see pic). When the tire is soft (air downed) and you hit a dip, the forces cause the tire to bulge out. And the tire comes in contact with the pinch seam. If OP's situation is close, I'd recommend trimming.
35s (see sig for specifics) that "passed" the tire flex test for pinch seam contact. That was freshly painted after the work. Could hear the rubbing while running the White Rim Trail--a pretty moderate trail.
You want a lift and bigger tires yet you don't want to cut your rails and pinch seam so you don't damage a tire or worse? What are you going to do when you get a little mud, a scratch and god forbid a dent in that new jeep??
Not sure why you are afraid of it. Maybe give it a couple months and your jeep will be old then. But seriously it will look better and perform better with the pinch and rail trimmed. Also you do know with a lift you have to take apart your new jeep right?
Attachment 496283
Attachment 496283
