Disconnects?
Disconnects?
There's a set from TeraFlex for about 120 bucks & a set from JKS for about 150 bucks..is there a real difference?
They seem rather straight forward and easy to install..
Any advice??
Thanks
Steve
Any advice??
Thanks
Steve
the TF discos are affordable and they work well. the JKS discos are adjustable and are beefier.
IMO the advantage of TF is the pin that holds the sway bar in the disconnected position. The JKS are also a nice piece but you have to zip tie or tie wrap the sway bar once disconnected. I've ordered the TF.
JKS "Quicker" Disconnects - zip ties aren't enough
I have the JKS "Quicker" Disconnects, and I got the really big wide zip-ties, and at least 1/2 the times I go wheelin, the zip ties are getting broken. I am looking for a better solution to keep the sway bar from moving. The zip tie isn't cutting it.
I am running Wrangler 285/75R-16 MT/R on Unique 16x8 12cm backspacing. Those tires are more like 11" rather than the 12"s many people run, so I have lots of clearance and they never rub.
Thanks
Kurt
Thanks
Kurt
