Disconnects
Im running the same lift as you, I use the JKS quicker disconnects, love them, super easy install.
JKS Manufacturing 2030 - JKS Manufacturing Quicker Disconnects™ for 07-13 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
I use Rough Country disco's too. They do their job, but I already had to replace the heim joints on both. They wear pretty quick. Otherwise they do work great. Also with RC's mounts, you can change the links to virtually any other brand, I'll be switching mine out for Synergy's.
Traction
This may be a bigger set up than you have but it's the best depiction I have seen of not disconnected vs disconnected.
The Reason Why You Disconnect Your Front Sway Bar. - YouTube
There is a significant advantage to disconnecting with stock height and stock wheels... so yes with 35's and 2.5 you will get more flex disconnected offroad and thus a more stable ride in the cab.
