Disabling ESP???
#22
#24
on the 07's and i believe some early 08's you have to have the comp flashed. i went to the dealer to have it done but going to cost me 160 bucks they said its not covered under warranty. i may just pull the fuse while offroading. does pulling the fuse disable the airbags?
#25
I have had my turned off for over 6 months now! The only thing is the esp lights stays luminated on the dash! If you follow the directions you will be doing donuts in no time!!
#26
ESP Crap
Not sure about how it works with the US jeep but i'm in Oz and when I pull the J6 fuse it dissables all the ABS, ESP & BAS. Gives more power and lets you drive YOURSELF.
BUT also speedo doesn't work and Ks (sorry Miles) don't clock up, Tacho still works so all good.
Ps, Also MILES per GALLON or whatever you get goes through the roof when you toggle to it, doesn't change your economy just that it must be able to read it properly, try 858 Ks per 100 litres. HaHa
Just thought this might help as some of the fixes you guys have only if we think of our cars as left hand drives,
EG, Unlock all doors with 1 push, Did the key and button thing and worked fine ut mates only works if he uses LEFT DOOR LOCK, our PASSENGER side.
Anyway hope it might help someone.
#27
so when yall are shutting the car off at the end.. are you turning it straight back on? i have been opening the door to get it to shut down all the way... also.. are there any 07s that have gotten it to turn off?
#29
I haven't read this whole thread so sorry if this is a repeat. There is a pretty comprehensive explanation of the ESP system and how to turn off certain copmponents of the system or the whole thing in this article from JP magazine...
http://www.jpmagazine.com/techarticl...tem/index.html
#30
I finally got it to work!
I put a watch on the dash so I could see the seconds tick...
the first clockwise half turn I did it exactly 7 seconds and let go, this time there was the initial 5 second beep, then another beep after I let go after 7 seconds...
on the counter-clockwise turn, there was no beep.
and the back to center turn there was no beep.
but when i turned the jeep off then back on, the ESP OFF was displayed in the odometer and the esp symbol was on. after about 12 seconds the ESP OFF went off, but the esp symbol stayed lit. so it's off now!!! can't believe it took me this long to get it to work.
