A different kind of axle question
Ok where to start... What I'm wondering is how much weight could a front dana 30 carry with stock tires and no lift. The question comes from this. When building my jeep I didn't want to do what I did last time. Which was lift, armour, winch, tires, and I just kept making it heavier so, my solution was to start with a better power plant to start so I was looking at bruiser conversions 4bt. From the numbers that I got for the engine and tranny
Stock is around 600 lb.
4bt is around 1000 lb.
Later on I will be swapping to a junkyard 60 in the front.
I guess where I'm going is should a stock dana 30 be ok or should I spend the $180 and truss it to be on the safe side.
Yeah your probably right I'll just truss the damn thing. As far as the added torque. I'm gonna go easy on it I don't plan on destroying my rear diff by gunning it off the line. That being said that problem will be solved when I swap out axles. Dana60 front sterling 10.5 rear. But it will be a while before I can get them to start converting them for jk use.
