Difference-2012 to 2014 (engine&tranny)
I understand they made a transmission change after 2012. If this is true is there a reason when buying used to avoid the year 2012? Is there anything else I should be aware of regarding the year 2012 as opposed to 2013 and newer. Also I'm considering installing an Atlas transfer case, any known issues with changing cases. Thanks!!!!
You may be right, but I was told that the tranny was different. I also heard that the computer won't let you change to an atlas due to the computer program. I need to know this before I make a purchase.
In 2013 they went to true auto-stick where you have to touch the stick for every gear change. It's just a preference issue for some.
Here's the A580 with the stock xfer case.
If you're referring to the automatic 5 speed there was a programming change between 2012 and 2013 models. For the 2012 models when you use the "auto-stick" it sets the highest gear the transmission will shift to allowing you to set it to '4' and the transmission will shift normally up and down but not shift beyond 4th. This is good for those who haven't re-geared and have larger tires since it keeps the revs up on the highway.
Interesting...my 2012 does not work the way yours does. Mine works as the owner's manual describes it...ERS or electronic range select shift control simply allows the driver to limit the highest available gear when the shift lever is in the drive position. For example, if you shift the transmission into third gear, the transmission will never shift above third gear but will shift down into second and first gear normally. The owner's manual does not mention anything about holding the lever to the side for two seconds (except for exiting the mode by holding the lever to the right until "D" is displayed) or any other mode of operation for ERS.
Sent using smoke signals
