Diff fluid
Old 08-09-2009 | 04:16 PM
funtimes's Avatar
Default Diff fluid
OK got to the 500 mile break-in on the new 5.13 gears so here's the question.....Live in South Dakota (cold winters and hot summers)....HAVE 4 DOOR RUBI..What Mobile 1 synthetic gear oil. 75/90 or 75/140?????
Old 08-09-2009 | 04:19 PM
08jk4door's Avatar
what does your manual say ? Fill up your Jeep JK Wrangler’s front differential with 2 quarts of SAE 75W-90 synthetic gear oil. DO NOT be tempted to fill up your differential with anymore gear oil or else it will get pumped out of the breather tube and make a big stinking mess.
Old 08-09-2009 | 04:20 PM
nthinuf's Avatar
Go with what the manual says.
The lighter weight in both.
The 140 weight in the rear if you do heavy off-road or towing
Old 08-09-2009 | 04:33 PM
funtimes's Avatar
Yes I know not to fill them to much but I was thinking the 5.13's would run hotter down the highway and the 140 would keep them cooler. Am I thinking right?
Old 08-09-2009 | 05:54 PM
bubba2u's Avatar
they say to use 140 for towing only in the rear diff. i will be going that rout at next change.
Old 11-11-2009 | 06:37 AM
REL1203's Avatar
when adding in 5.13 gears, do I need to use less oil in the front for any reason? I keep adding in the same amount of oil as before the gears, but it seems to always have some come out the breather and makes a mess?
If I add to much Gear Oil, will anything else happen besides it come out the breather, like leak out one of the sides of the axle? Anything else?
Old 11-11-2009 | 04:15 PM
08leocon's Avatar
Where in the manual does it say two quarts? i found what fluid to use but never saw the capasity
Old 11-11-2009 | 04:35 PM
aldaman's Avatar
This was taken from the Project JK....The front takes ~ 1.35 Qts, rear 2.375 Qts
Originally Posted by PROJECT-JK.COM
Front Differential Capacity:
2.7 pints (1.35 quarts)
Rear Differential Capacity:
4.75 pints (2.375 quarts)
http://project-jk.com/jeep-jk-write-...hange-write-up
Old 11-11-2009 | 06:03 PM
joe002's Avatar
No, go with what the Owners Manual recommends. If you don't tow use the 75W-90.
As the manufacturer recommends the 75W-140 is to help protect the gears from the extra pressure put on the surface of the gears when towing. FYI - the shop that installed my 5.38 gears down here in pretty hot Phoenix recommend the stock 75w-90 weight.
Old 12-20-2009 | 06:22 PM
BLK-JK23's Avatar
for the 2010 it recommends 80w-90
