Diff covers
Diff covers
I know I know this is most likely already a thread but Im on my way out of work and I really would like to know...
I have ARB diff covers sitting in my shop at home and Im going to install them this weekend before a car show so what do I need to get for Oil? and do I need a new gasket or can I just use the old one?
Thanks. Rodney.
Thanks. Rodney.
royal purple for fluid
rtv for gasket. clean off the old stuff real good. or u can always get lube lockers. they're reuseable and cut to fit.
also WOL did a write up in the 'write up' section. search 'changing your differential fluid' or something like that...
Thanks. Rodney.
Thanks. Rodney.
If you do not tow, or head into extreme trails, any 75-90 gear oil will meet your needs for the rear. If you have a limited slip, don't forget the additive.
For the front 75-90 will do fine.
If you do tow or hit some extreme trails in the summer months, than 75-140 should fit your needs.
That said, when I say any what I mean is any synthetic.
Royal Purple is a good oil, as are a few others, but at any rate Synthetic is a must.
I use Amsoil in the diffs.
As for the amount, can't help you with that, but as I recall the ARB has a fill plug, and normally fill to the plug.
