diff cover question...
#21
the dealer is using the following to fill one diff:
less than two quarts of diff fluid 80/90w at approx $5.99qt for synthetic (autozone price)
1- 4oz bottle of diff additive (limited slip stuff)= 7.99 (local stealership price)
and about a dollars worth of RTV sealent
definatley under 25bucks times 2 diffs and it's still under 50 for sure. I would take them to task for trying to fleece you like that
![eek 2](https://www.jk-forum.com/forums/images/smilies/sSc_eek2.gif)
#24
#25
JK-Forum Founder
no. friction modifier is only needed with a limited slip diffs. however, just about every high quality synth diff fluid already has friction modifier in it and you will not need to add more even if you do have a limited slip.
#27
JK-Forum Founder
nope, never had a problem on my TJ or on my JK. as far as leaking goes, your friend most likely didn't do a good enough job of cleaning up the old gasket/rtv and or didn't do a good job of apply the new gasket/rtv.
#28
I don't know if anybody has mentioned this or not but there is a good chance of the track bar hitting the solid if your not lifted. The only way I know to correct this is a after market,track bar like a JKS. I'm speaking of the rear not sure about the front. They are a very nice cover however.
#29
![Talking](https://www.jk-forum.com/forums/images/icons/icon10.gif)
My Solid D30 diff cover has rubbed my trackbar at full flex and rubbed the powdercoat off a little bit. now the ridge above th "D" in Solid has flattend out only on the very edge... Any one else have this? No complaints, just a little mark...
#30
JK-Forum Founder
![crazyeyes](https://www.jk-forum.com/forums/images/smilies/crazyeyes.gif)
