diff cover noobie questions.
hey everyone,
When looking at a website such as northridge4x4, there are diff covers. I am looking at the psc bombshells. I was going to buy the dana 30 front for my wrangler x and the dana 44 for my rear. Do these go on either the front or the back of the diff? should i get diff covers for the backside of my diffs as well as the front side? Do 2 diff covers come in a pack?
I am super confused on this.
Thanks soo much!
Sean
Thanks soo much!
Sean
The dana 30 and dana 44 covers have different bolt patterns and you will need a specific cover for each. You don't have to get both covers but I would recommend it. They are usually purchased separately unless someone is running a package type deal.
hey everyone,
Thanks soo much!
Sean
Thanks soo much!
Sean
on the front dana 30 the diff cover goes on the front of the housing . the dana 44 diff cover mounts on the backside of the rearend housing. If you look under your JK you will see the bolts where they mount and on the opposite side where the drive shafts come out and that might explain it better for you to understand. the covers are sold separately and the D30 has a different bolt pattern than a D44, so you would need 1 D30 cover and 1 D44 cover
thanks,
Sean
when you look at the diff, where you see the ring of bolts, that cover is removed and your new cover bolts in. you swap them out. only 1 d30 cover and only 1d44 cover
If you are going to get diff covers then you realize that you will most likely also be due for a diff fluid change, correct? I put on a cover and the diff started to leak after tightening the bolts down, also- the dealer just replaced the gaskets and fluid about 2 weeks ago. Needless to say- lubelockers are on the way.
Edit: You only need 1 of each cover unless you are buying covers for me too!
Thanks everyone for the quick and informative replies!
i am getting all my bumper and armor stuff ordered up here in the next week or so...just had 30 hrs overtime on my last paycheck =)
Thanks again!
Thanks again!
