DIE TECH EVAP RELOCATION..... Check engine light ON!!!!!
Old 04-14-2010 | 05:16 PM
jasonG's Avatar
Default DIE TECH EVAP RELOCATION..... Check engine light ON!!!!!
Anyone do this MOD with DieTech?? I did and about 4 days later my engine light came on. My friend ( jeep chryler tech over 20 years ) said this could be an issue for cutting the hoses. The intructions said to "ziptie" after install where cut. My thought is that there's obviously air leaks so today I put hose clamps on all areas cut (4 places)
So I'm asking for any advice or someone who has ecountered this problem. Thanks in advanced
Old 04-14-2010 | 07:22 PM
seer1's Avatar
Make sure you didn't reinstall the cannister upside down. Also, if you messed with the white thing that connects to the cannister, check the o-ring that goes between the two. If that's missing or twisted you'll get the light. If you're sure it's the lines, try some self fusing silicone tape underneath the hose clamps. h**p://www.amazon.com/Rescue-Tape-RP2567-Fusing-Silicone/dp/B000ZTM734
Old 04-14-2010 | 07:29 PM
wayoflife's Avatar
JK-Forum Founder
definitely clamp the hoses. drive your jeep for a while and assuming that the leak was coming from there, the light will go off in time or, if you want, disconnect your neg battery cable for about 15 min or so and that should clear the light too.
Old 04-14-2010 | 07:40 PM
jasonG's Avatar
Thanks Guys.... I should of known better when the directions said ZIPTIE I love zipties, duct tape, shoegoo etc.... but new the zipties wouldn't be enough should of listened to my gut.. Thanks again for all the help guys.
Old 04-14-2010 | 07:42 PM
wayoflife's Avatar
JK-Forum Founder
LOL!! well, if that doesn't do the trick, what seer1 said is pretty right on. if the o-ring between the white box and the evap is damaged or missing, that will trigger your light as well. i've been able to fix this problem with some simple rtv in the past.
Old 04-15-2010 | 06:14 PM
jasonG's Avatar
Wayoflife,
spot on. Did the hose clamps last night and today the light went off.
So for any newbies like me doing the evap relocation PUT HOSE CLAMPS ON
Old 06-08-2010 | 03:36 PM
RebelJeeper's Avatar
Wayoflife,
Any pictures by chance of the finished product? I'm considering this (and other relocate kits). Any problems since?
Quick Reply: DIE TECH EVAP RELOCATION..... Check engine light ON!!!!!
