Diameter of hub flange change from 2007,08 to 2014? Problems with wheels
#22
nvm, I now see where the wheels are not sitting flush with the hub. The centercaps will inhibit you from getting the wheel to slide over the hub flange so I jumped the gun and assumed that was your issue. Sorry I don't have any real advice to give.
#24
Ah, I see. Thanks anyway.
#26
Ooooookay. You folks with procomp steelies absolutely must have a smaller hub flange or don't know that your wheels are only touching around the outside like mine where. Just got my new procomp 152 15x10 5on5 3.75"BS wheel in to check and see why folks can run pro comp... The answer is.... you can't. At least not on a 2014 jk. These two pictures show my black rock 952 rims(with the paint scrapes) and the new procomp 152 rims(no scuffs). EXACT SAME MOUNTING SURFACE. Even procomp told me, when I called, that nothing extended farther in than the mounting surface and that's not normal for a wheel.... Well have a look at their rim, it's got an extruded concentric circle around the mounting surface sticking farther in than the mounting surface. I don't think he was blatantly lying to me, I just think he was too lazy to listen to what I actually was asking and threw out a generic answer.
Anyway, there's no way in hell this can ever sit flat against my jks hub. I doubt it does on anyone else's. It may be worth pulling off and making sure you are hitting the mounting surface and not just the edge of the wall around it.
#28
Hmm. I'll not busy tonight so ill just go pop a wheel off and let you know in a few minutes. You mean rotor or hub flange with the studs sticking through it?
