Diameter of hub flange change from 2007,08 to 2014? Problems with wheels
Take off the two star clips on 1st and 4th stud. They are interfering with the wheel fit. I just used a pair of lineman dykes to cut in two places to get mine off.
EDIT: I see jdmnt beat me to the punch...
The issue isn't 15" wheel but could be steel vs. alloy. Stamped steel needs the flange for strength or else it would flex. I'm thinking those running 15" steel are using wheel spacers to clear the flange, since the diameter of spacers are less than diameter of rotor. The spacer sits inside the flange of the wheel and makes flush contact. Only way to test theory is for other 15" steel wheel jeepers pipe in with pictures and details.
haha I wish I didn't have them on there in that picture. It's hard to get folks to see past the clips being on there. I do understand that they should be removed, but the wheel is scrubbing against the hub flange before it even gets to the retaining clips. You can see all the ground down spot around the extrusion on the wheel.
I see what your saying with scrub marks on the rim where the hub is smushing against that inner lip of the rim before it has a chance to sit flush. Looks like the lug holes are right next to that ring/lip. Not sure a spacer would even work. Looks like a spacer fitting inside the lip would be close!! Sent from some string and a few tin cans.
I see what your saying with scrub marks on the rim where the hub is smushing against that inner lip of the rim before it has a chance to sit flush. Looks like the lug holes are right next to that ring/lip. Not sure a spacer would even work. Attachment 542422 Looks like a spacer fitting inside the lip would be close!! Sent from some string and a few tin cans.
Thanks! I like the trackers and I also like the MB razors, I just feel like I need a fake beadlock around the lip to break up all the black. If I can't get info on the procomps that folks are running, I'm probably going to go with the razors. I may even have summit ship me just one of the procomp rims and fit check it. I'll lose 30 bucks on return shipping, but at least I won't have to do anymore research haha.
Bit the bullet and bought a 15x10 5on5 Procomp 152. 3.75"BS just to see if it will fit or not. $30 dollars for return shipping is worth way less than the amount of time and effort tracking down information about these things. Should be here in a few days from summit.
