Determining Bump Stop Landing Pad Length
karls10jk (03-06-2020)
A simple way to determine this. With the vehicle sitting at normal ride height (sitting on its tires) measure the free shock length on the shock rod. Then measure the diistance from the top of the lower bump stop to the bottom edge of the upper upper bump cup on the frame. (Don't measure just to the rubber bump stop cushion, that will compress nearly flat under pressure.) If the distance between the bump stops is less than the free length of the shock rod you're cool, if it's more, then you need to add bump stop. As metioned, it's good to have a bit of extra on the shock travel to prevent bottoming out.
This doesn't tell you anything about tiire to body clearance under full compression. You pretty much have to one way or another figure out if you'll clear by stuffing the tires on a rock, use a forflift, etc.
Let's have a community forum but don't post any questions, kind of sounds counterintuitive. Starting a new thread helps cultivate someone else's new idea, opinion, or experience that can be shared and be relevant instead of being buried into years of older threads. Not going to entertain this discussion any further, this will be my final reply or comment on this matter.
What chaps my ass is someone that does no know what they are doing presenting themselves as some kind of expert or professional in the business to get clicks on a website so they can get payments, sell advertising, or get free stuff. Giving poor or incomplete info to those even dumber (uneducated) the the site holder. You want to come on here and get free advise and information (that is very basic and is already been done 100 times in treads that can be found by simply searching) and use our knowledge for your benefit. I don't know if you basic questions are to really gain knowledge or to boost your post count so people can see the links in your sig so you can get clicks.
If the mods here don't care that fine, maybe I will put the link to my business in my sig and start getting free advertising.
