Determining Bump Stop Landing Pad Length
Old 03-05-2020, 06:44 AM
Dirt Hammer's Avatar
Default Determining Bump Stop Landing Pad Length
Team, I added a 1 inch spring spacer up front to my 2.5 AEV lift for a total of 3.5in. The bump stop landing pad, should I add a length of 1 inch to it?
Old 03-05-2020, 08:54 AM
karls10jk's Avatar
You'll get generic answers but the best way to do it is to measure it out. Take your compressed shock length and see if you allocate that amount of space where you bumpstop goes, what hits first. If it's bumpstop then you're fine. If it would be shock (give yourself a good 1/4" buffer) then yes to the addition. My gut is saying no need for additional bump though.
Old 03-05-2020, 08:59 AM
Understood, my current shocks are Rancho RS9000XL for 3-4 inch of lift. Would this not throw off the measurements?
Old 03-05-2020, 09:04 AM
Looks like my compressed length is 16.85inches. So as long as I have less than 16inches between the bump stop and bump stop pad I should be good?
Old 03-05-2020, 10:08 AM
karls10jk's Avatar
If you've got 16.5" between the pad and the fully compressed foam piece (most will measure to the cup) then your shocks are protected from over compression. Are we safe to assume you don't have a drag link flip where you'd require more bumpstop you to protect the fresdrag link?
Old 03-06-2020, 06:21 AM
No drag link flip here. Thanks for the help, I'll measure this weekend.
Old 03-06-2020, 08:02 AM
TheDirtman's Avatar
Do you work for extreme terrain?
Old 03-06-2020, 08:07 AM
No, I buy a lot of parts from them, plus they are a partner as well.
Old 03-06-2020, 08:08 AM
TheDirtman's Avatar
A partner in what?
Old 03-06-2020, 08:17 AM
A partner in what?
Partner of mine for discounts on parts I buy.
Quick Reply: Determining Bump Stop Landing Pad Length
