Delayed throttle response
#21
engine lag
I noticed the lag more with automatics, particarly when doing a rolling turn and trying to accelerate on the new road... real delay in response. I drove several automatics when I was looking to buy a JK. I stuck with the MT6 because I feel like I can shift around the lag. But the six still has a labored feel at low RPM, as if the Gerbels are trying to get in sync on the wheel or something.
#22
No, the superchips tune does not help with the lag that you sometimes feel between shifts. It does improve throttle sensativity. But I believe the issue with the hesitation that is felt around 2,000 RPM, especially for 6 speed owners after a shift, is related to the ECU severely retarding the ignition timing for some reason.
#23
I think we're talking about 2 different things here. The flashpaq (which I've owned for a very long time now and am very happy with) does improve throttle response. But there is a definate hesitation around 2,000 RPM when going from off-throttle to on-throttle that I believe has nothing to do with the electronic throttle. That hesitation was there before the flashpaq (i.e. stock) and after. There have been a lot of threads about this hesitation, mostly from 6 speed owners.
The hesitation does not happen 100% of the time, and I notice I get it a lot more when it's hot outside. I've been watching several engine parameters and when it occurs it looks like there is a large reduction in timing advance (like 20 degrees).
If you have an auto you may not notice the problem that I'm talking about. Also I wonder if Chrylser ever addressed this in later models. So if you don't have the dreaded 2K RPM hesitation it may be because chrysler made a change at some point.
Maybe I'll start a poll so we can figure out who experiences it and who doesn't.
#24
What is being described sounds a lot like the PCM torque management. Basically putting a pillow between the hammer of lower end torque by retarding timing to lessen wear and tear on driveline components.
#25
I have an 09 MT6 with 5k miles on it and I am having the same problem. MIne will come to a complete stop at times and then take off. (mainly in an off road sit with heavy torque). Also any one else having a problem with the engine not reving down between shifts? I have tried to change shift points etc.
#26
Good call JPop! I've also been wondering if it's torque management. I know this is a very popular scheme lately with manufacturers. I heard the new Camaros are picking up something like 1 second in the quarter mile when the tuner removes the torque management.
That would definately explain the serious reduction in ignition timing with no corresponding knock event.
I wonder if this is something Superchips could possibly remove.
#27
#28
Here's the post that references it.
https://www.jk-forum.com/forums/show...39#post1833239
