Decisions on my lift. 2.5 Coil lift
Originally Posted by scooby snacks
Don't forget you will also need exhaust spacers to avoid interference with your front drive shaft.
This is my main concern. I will replace the rear bumper and add a tire carrier. I may replace the front bumper as well. Should I go with the TF 2.5 lift and spacers if needed? OR should I go with a 3inch lift. Will the extra weight bring the 3 inch down a bit to where the drive shaft anlge will not be a problem? Main concern is the drive shaft angle. I do not want to have to replace the shaft.
