Death Wobble Question: Drag Link lift/non lift
#21
The one thing you need to watch for if you do much wheelin and get some articulation up front is that many front springs will contact and rub on that bracket right there it sticks out and where the sector shaft bracket would attache to. I finally removed my sector shaft brace and cut that section (tab) off.
we mostly flat tow ours, id love to do more wheeling but theres not much around me (close).
#22
otherwise i'd put the Synergy Track Bar Brace on it sooner than later - the steel is significantly more substantial than the OE (thin) mount - and its only $100 and a little time.
I had the FULL Grade 80 bolt kit on it very early on & it did not prevent DW, so I'm not convinced thats worth the expense....the Synergy Track Bar Brace include the better (grade 80) larger bolts anyway.
#23
I will say....I wheel pretty aggressive. I added that SS brace cuz I got a deal on it at the time I was putting the TB brace on anyhow. At the time I had the Synergy TB as well. I switched TB's and the sector shaft brace doesn't play nicely with other branded TB's, so it came off.
#24
#25
just flat towed the JK 1400 miles - and as i watched it in the rearview camera i can tell its tracking straighter (no back an forth) than it ever has.
I always questioned the amount of torque "steer" my (manual shifting) JK had...every gear change a little back and forth / sideways motion almost since new....and now even that is gone w/ the bracket installed!
