Death wobble question
Has anyone ever heard of bad or worn out front shocks or bushings, or unevenly worn front tires causing death wobble? My death wobble occurs after 55MPH when hitting almost any imperfection on the road. New OEM steering stabilizer replaced a Skyjacker dual stabilizer set up where on shock was blown out and one was locked up.
Thanks
Thanks
Yes, people have posted that bad tires, shocks, joints, bushings, etc, etc, contributed to deathwobble.
But rather than guessing or throwing parts at it, start with a balance/rotation and then go through Planmans DW/Shimmy diagnosis a few times to actually check the various components and the torque specs. (it is stuck right to the top of the Writeups area).
Thanks
Thanks
"My death wobble occurs after 55MPH when hitting almost any imperfection on the road"
Make sure you are not confusing "death wobble" with bump steer. Death wobble (called speed wobble before Jeepers coined their own term) has little or nothing to do with rough terrain. Death wobble is an oscillation of the front wheels caused by a lack of damping. The wheels vibrate uncontrollably. Think of a shopping cart wheel that suddenly starts to dance all over the place as you are pushing it along. Bump steer is a Jeep's tendency to have it's path deflected by an object in the path of one wheel (or road imperfection). Bump steer is inherent on every single Wrangler, even factory new, due to the design of the steering/suspension but it is especially exaggerated as the Jeep is lifted incrementally higher. There are different remedies for each condition so make sure you identify your problem before you throw money at it. You can find numerous videos online of true death wobble if needed.
B4 we decide what problem you have. Your so called dw. You will know if you have a true dw. Do you have to pull over everytime you get one? Or slow down? Or feel like your jeep is falling apart? When I had it, The jeep was undriveable. I had to pull over 6 times in a 10 mile distance. Every bump or dip in the road caused one.
Without starting the vehicle saw the wheel back and forth slightly, if you look out the window down the side of the hood see if the whole cab is moving before the tires begin to turn. If so shocks and tires are not the cause of your wobble. I'd look into the track bar, mounts, bushings, and then control arms, then steering links. In that order.
To answer some questions:
I did refer to Planmans write up and couldn't Diagnos it.
It's defiantly not bump steer. When it occurs, the violent shaking is still there as I'm slowing down and continues until I've stopped.
I'm thinking it may be the front shock bushings as everything else is tight as it pertains to linkage, etc. The shocks are about due for replacement so I'm starting there. And I'm going to rotate the tires. Doing both this coming weekend.
Not for the death wobble issue, but wife and I are probably going to sell the jeep for a different vehicle anyway. Need more family room.
