Death Wobble Northridge Bolt Kit
Old 09-14-2012 | 07:06 PM
  #81
c17loadmaster's Avatar
Originally Posted by c17loadmaster
Im pretty sure that the 14mm bolts are only for the upper trackbar mounts on the 2012 Jk's. Thats what I remember anyways. All the other years use the 9/16th bolts. There was a add on the billboard for $115 bucks a guy was selling a bolt kit he made and he posted. Excell sheet he made with very detailed locations of what goes where. That thread is where i think i saw the 2012 comment about the upper trackbar mounts being a solid 14mm.
This is from northridge4x4's website. The 14mm bolts are only for the 2011-2012 JK.
Fits 2007-13, Jeep JK Wranglers, Grade 8 Bolt Kit, Lower Control Arms and Track Bars.
*NEW FOR 2011 - 2012 JKs - Includes a 14mm bolt and lock nut to replace the Front Track Bar Frame Side bolt.
CLICK HERE to check out a Great Video that shows why you need this upgrade
Kit Includes:
(4) Domestic 9/16-18 X 3" Grade 8 Hex Head Cap Screw Yellow Zinc
(8) Domestic 9/16-18 X 4" Grade 8 Hex Head Cap Screw Yellow Zinc
(12) 9/16-18 Grade C All Metal Hex Lock Nut Zinc
(24) 9/16" Super 9 SAE (Type A Narrow) Flat Washer Yellow Zinc
(2) 14MM bolt and Lock Nut Zinc
Old 09-14-2012 | 07:07 PM
  #82
bushpilot's Avatar
1st theres only one track bar on my 12, not an upper or lower (as your post might lead one to believe)....and honestly, while i appreciate your GUESS....i can <obviously> do the same, and ive got the bolts (apparently you don't) !
so again the point is...w/out any f'in directions theres no way to KNOW !
and if i buy a product i sure as hell shouldnt have to go SEARCHING for directions or confirmation of how its put together. Im not stupid...ive worked on plenty of cars / trucks....but its irritating as hell to be shipped a bag of bolts w/ no info ! Hell i got more directions w/ the DIFF covers ive installed (and im pretty sure theyre fool proof) !
Old 09-14-2012 | 07:14 PM
  #83
JKingAround's Avatar
There's two bolts on that track bar an upper and a lower
  #84
Wasnt trying to offend you man. There are 2 trackbars. One on the front axle and one on the rear axle. They each have 2 ends. There are 8 bolts for the lower control arms and 4 bolts for the trackbars. I actually did replace all my bolts, and when i got the kit it did not have the 14mm bolts. ( I have a 2009). The upper control arm bolts do not get replaced. I certainly wasnt calling you stupid or anything. I was just offering my advice, and I confirmed my advice by posting the northridge4x4 add. It simply explains why you have 2 extra bolts. Which is what I gathered from your initial post asking where those 2 extra bolts go.
I do have to say it sucks your kit did not come with instructions. I got mine before they changed to kit to accomodate the 2011-2012.
Old 09-14-2012 | 07:22 PM
  #85
bushpilot's Avatar
yup sorry im just pissed and frustrated.
I wasnt aware the kit included anything for the rear (i figured it out obviously)....but again
w/out directions theres a lot of uncertainty.
theres als no indication (via web or other wise) that some owners will end up w/ xtra bolts....
again its just piss poor and short sighted....i dont need directions per se (some probably would), but even a list or indication of which bolts / where would have been EASY to include !
Old 09-22-2012 | 11:30 AM
  #86
Wgrin's Avatar
that youtube does not show where 12 bolts go...
i figured it out & im still not pleased !
I called north ridge - they claim there should have been directions, i asked for 'em to get a copy and although he claimed to be reading them - he couldnt tell me where the 14mm bolts went.
the guy at NR 1st claimed that silver 14mm's went up front, then he said one in the front and one in the rear...but couldnt tell me what side the "silver" 14mm went on....
as it is, i found that the gold 9/16s fit better in the rear track bar (the 14mm's had some slop in 'em).
unfortunately ive got one of the 9/16s in the track bar frame mount, im told that one should be a silver 14mm...well now i cant get the 9/16s bolt out...so im stuck w/ it the way it is.
from what i can tell the 9/16s fit tighter in the sleeve anyway (probably why i cant get it out), theres no slop in it, thats for sure. even on the passenger side (track bar) mount the 9/16 bolt fit better.
the entire experiance would have gone a lot better if there were some directions ! Id be interested in hearing from anyone else that has recv'd this kit and if they saw any directions or not.
I'll be checking w/ another friend who bought the same kit (hasnt installed it yet).
I had, had the same issue when I got it. No instructions no idea it was for the rear. The kit did nothing for me though. A new stabilizer and a bracket to relocate the control arms back to stock did it for me.
Old 09-22-2012 | 06:31 PM
  #87
5.56x45mm's Avatar
My Northridge bolt kit had no instructions. I read somewhere that the 14mm bolt was for 2012 models only. Stupidly I did not test fit it after the stock bolt came out. I now have a 9/16 bolt STUCK REALLY TIGHT into the frame/upper side of the front track bar.
For all I know I have fubar'ed my bushing trying to hammer it out from the back side, now i'm out of ideas for getting that bolt out of there. If no luck tomorrow, I will need to have the jeep towed to get undone by at the damn stealership. I can't drive it like this FML.
Old 09-22-2012 | 06:41 PM
  #88
Wgrin's Avatar
Try moving your steering side to side you may need another set of hands. Mine did that too and I got it out
Old 09-22-2012 | 06:42 PM
  #89
5.56x45mm's Avatar
I wil try that. Thanks.
Old 10-10-2012 | 07:19 AM
  #90
CM5280's Avatar
So, like some others, I've been fighting death wobble on my 2008 Rubi Unlimited (Teraflex 3.5" Lift on 35x12.5" tires) for some time. I bought the Northridge bolt kit and noticed a couple of things while installing:
1. I have the Teraflex adjustable trackbar. The frame side bolt went right in with no problems. The axle side bolt wouldn't go through at all. I pulled the trackbar off and tried to push the bolt through, but the bolt shoulder wouldn't go through as it's too big - tried several other bolts in the kit with no luck! I went to Napa and bought a 9/16" course-thread bolt and it works fine - weird.
2. When replacing the lower control arm bolts, the driver side went pretty smooth. The passenger side was a real pain! When I was putting the frame-side bolt in, I noticed the hole was off-center and the bolt wouldn't go through. I had to ratchet-strap the axle and pull it towards the rear of the vehicle before the hole would line up so I could get the bolt through. Does this seem normal or is something out of whack with my axle alignment front to rear??
Nonetheless, took the Jeep out and found a nice bridge expansion joint doing about 50 mph - boom! Death wobble and frustration continue!
CM
Quick Reply: Death Wobble Northridge Bolt Kit
