death wobble help
my tire guy did say that one of the rear tires did take alot to balance so im wondering if he just gave up on the fronts??? one thing to note is that i thought by reducing the tire pressure it might help since i was only running 28 lbs in my bfg's so i dropped the pressure from 36 to 30 and it seems to be worse. its also gotten worse since the temp dropped into the 10's in the south???
Got MTR's about 4 months ago. Took 3-4 balance attempts to get it to a point where it was negligible.
INSIST ON DYNAMIC BALANCING! It won't be offered, you must request and it will look nasty with weights on either side of wheels, but, I chose that option over DW.
ANd you need to make sure the shop can do a TRUE dynamic balance. I had mine done a few times until I found a shop with a Hunter GSP 9700 balancing machine. That did the trick. Other machines will work but make sure they take their time and do it right.
A spin balance is NOT a dynamic balance. Get a dynamic balance and I think you will have this solved.
I believe most references to dynamic balancing refer to a high speed spin balance as opposed to a static bubble balance.
Many shops do not have spin machines big enough to accommodate large offroad tires (35"+) that weigh 100+ lbs.
Laterally moving a 100 lb 35" spinning wheel would create very large off axis torsional forces.
UPDATE:::::
I had my front tires taken off and road force balanced. When i drove it back from the shop i had no wobble but the real difference came when i installed the dual steering stabilizer from rough country. That made all the difference in the world in terms of feedback and now the steering wheel is somewhat firm again.
same problem
i had the exact same problem with 35" tires and a 4" lift. The problem was one of the control arms was knocked a little tighter than the other. So basically a thorough alignment job did the trick. I even went so far as to buy new tires before finding out that the problem was just one control arm was shorter than the other, effectively putting my front axle at a slight angle. It was just enough to initiate that wobble. I just marked the nuts with some paint and now i check them everytime I go wheeling.
Let me know how that rough country steering stabilizer works for you, I'm considering the same purchase.
