The DEATH WOBBLE database
Old 08-31-2009 | 12:56 PM
  #81
hmf's Avatar
hmf
1. Year and Model
2007 2-door X
2. Current Mileage
25,000
3. Approx mileage when DW started
25,000 immediately after 2.5" lift installed
4. Suspension (OEM, etc. Make sure you list all components like AM trac bar, CAs)
2.5" Skyjacker lift kit (springs/shocks/steering stabilizer)
Everything else OEM
4. Wheel/Tires/spacers
33" tires
5. What measures you have taken to resolve DW
Torqued down front track bar bolts to 125 ft/lbs
6. What was the"fix" or are you still dealing with it
Got realigned, no fix. Turns out the front track bar relocation bracket was flexing slightly when I jerked the wheel back and forth. Had an offroad shop re-torque all front track bar bolts and weld the relocation bracket onto to the existing bracket. Problem solved. Considering a Teraflex adjusting front track bar just to be safe...
