Death Wobble Continues...
After having dealt with this for months and torquing every component to spec according to Project JK's listing and checking it every 2 weeks I'm at a loss. Does anyone think adjustable control arms would help the situation? I'm sitting on a TF 2.5" coil lift, stock rims tires, and wheel spacers.
Have you checked all the joints for wear/failure? Or checked the mounting brackets for failure? Not even close to an expert, but just something I've read about. As for lower control arms, I have the teraflex ones and they work great, but not sure if it would fix your problem.
Seriously good luck man, I hope you find a solution.
Cheers
Cheers
It's definitely Death Wobble. The jeep will shake uncontrolable until until you come to a stop. the steering is flighty but i figured that was because i didn't have adjustbale control arms.
