Death Wobble??
#21
If we were talking about a TJ here, then yes, I would absolutely agree with you. In fact, adjusting the toe-in is the first thing you should do right after installing any lift as the drag link on a TJ is directly connected to the tie-rod. But, we are talking about a JK here and as you may not be aware, the steering setup has been redesigned with the drag link connecting to the steering knuckle independent from the tie-rod. Needless to say, a lift will not effect your toe-in at all.
