Death Wobble??
I had it whe I had a bad toe in
I would have your toe checked. Mine was really bad it seems from the factory? After adjusting it everything (knock on wood) is OK. I only figured it out after I noticed my tires wearing really bad.
Ruby Red
Ruby Red
JK-Forum Founder
You know, now that you mention it, I'm pretty sure that doojer's toe-in was way off from the factory as well and enough so that it was causing his tire tread to scalop. Add a lift and this could be a potential source of DW.
1. With a new lift and tires, the most likely culprit is the track bar. Tighten it, even if you don't think it looks or feels loose. Also check your control arms. After 1000 miles on a new lift, you really should re-tighten everything.
2. If the track bar tightening doesn't help, get your tires balanced. Yes, out-of-balance tires, especially the bigger they are, will cause the death wobble.
3. If none of that works, your control arms may be too short for your lift. Most of the time, you don't need to adjust control arms for a 3" lift, but sometimes you do--no two Jeeps are alike.
4. After doing all of that, if you still have some wobble, change your steering stabilizer.
Good luck and keep us posted on your progress.
It occurs to me that jtlr never answered back on what brand/model lift he had. And before we all give him ideas on how to fix death wobble maybe we should find out if that is truely what he felt and not a bad case of bump steer.
A front track bar bracket that changes the angle of his track bar could cause that situation of right, left, right, left series of steering over corrections and esp corrections while breaking. He may have had a situation like that instead of actual death wobble. Just a thought.
Sorry took so long to get back( have to work to upgrade this thing) its a 3" tereflex. I have 35x12.5 procomps on the factory 17's with 1.25"spacers. It definately was not a bump steer issue.(although I do get that ocasionally)
So basicaly check the track bar? Then check balance in the tires?
I'm going with toe-in. Happened with the TJ with only a 2.5 in. lift. Before you go spending the money for an alignment, tire balancing and spending countless hours under the Jeep trying to tighten tight bolts and over torqueing check out this write up. Checking toe-in, and then fixing is as easy using a tape measure.
http://www.stu-offroad.com/steering/align/align-1.htm
JK-Forum Founder
