death wobble
Just changing out those bolts would not have fixed your issue if the mounting holes were oval shaped. When you replaced the bolts did you look the brackets over really good. My trackbar bracket holes were worn out. I would start there. Look at those mounting holes real good.
If everything was cool until you changed from the stock ss maybe you should go back to a stock ss? Or whatever damaged your original ss may have also damaged something it was connected to?
