death wobble
death wobble
So far this week I have experienced death wobble four times, once at the beginning of the week and three times today. I have almost 36,000 miles on the original ball joints.It all started after I replaced my SS. I trashed my stocker at Bantam Fest and bought a Fox SS. I hope replacing the stock ball joints solves the problem.
x2. check the trackbar bolt holes and make sure their not wallowed out. after make sure its torqued to 125ft lbs. Swapping the bolts out for 9/16th might help a little too
suspension is only a few months old and i was told by my mechanic my ball joints were starting to show wear but would pass state inspection.
14MM..Northridge 4X4 just dropped the price of their bolt kit down to $40
http://www.northridge4x4.com/shop/nr...k-hardware-kit
My DW is the reason I found this site. I read through Planman's checklist and fixed my issue. In my case it was the trackbar mounts too. At only 22,000 miles.
I would seriously read that checklist and follow it step by step. You may be changing your ball joints for no reason.
If you indeed have death wobble (for whatever reason), a new SS will only mask the actual source of the problem. Theoretically, if everything is torqued down and working fine you should be able to drive normally without a steering stabilizer.
I know DW is almost always caused by a loose track bar. Torque your track bar to 125 ft/lbs and see if that works. I constantly torque my track bar whenever I have a project on my jeep. I figure I'm already working on it, might as well take a few more minutes to torque down my track bar again. I'll be switching to Grade-8 9/16" bolts soon as well.
[QUOTE=Croce;3178232]14MM..Northridge 4X4 just dropped the price of their bolt kit down to $40
NR4X4 Jeep JK Grade 8 Hardware kit
cool thanks didnt even know there was a kit
OK so I looked over the replies I received and did the mentioned 9/16X3 grade 8 bolt swap. I got my hardware from a local store along with washers and nut.I torqued both track bar bolts to 125lb/ft. That was yesterday and things seemed better until tonight when my family and I went for a drive in the country. I hit a bump or hole in the road and it started shaking the front end uncontrolably until I brought my Jeep to a stop. I am scratching my head over this and I don't want to be chasing my tail here. My thinking is it is the track bar and that it needs to be moved upward by means of a relocation kit, any thoughts?
