Death Wobble
I use to have bad bumpsteer with a 01 TJ, I went over everything ten times, then finaly I droped my front tire presure to 27 psi on 35 baja claws it helped alot.
Get a buddy. Have them slowly turn your steering side to side. Look for play as he turns the wheel.
It's either:
Loose bottom trackbar bolt.
Loose top trackbar bolt.
Bad lower trackbar bushing.
Bad upper trackbar joint.
Stripped/loose pitman arm.
stripped/loose/bad drag link joint on top or bottom.
Loose or bad tie rod ends.
Bent.deffective front rim.
Deffective tire.
if none of these items solve your problem you have a deficient lift installed with improper front geometry which includes your front component angles or your control arm lengths or bushings.
Good luck! Might was well turn the jeep in to a pre-runner if you have the money and it's 2wd. Maybe some long travel coil overs up front and tube fenders?
It's either:
Deffective tire.
Thanks guys. I'm heading over to the mechanics later this week and I'll definitely bring all this up. He's a buddy so I'm gonna hang out while he works on it and go over everything. I would just be happy to find the problem at this point!!
well
Well.. if you think lifting your jeep tested your OCD then I wouldnt recommend letting a dog ride in your jeep then. I went through the death wobble bit and once that was taken care of white dog hair became my arch nemisis.. its still an ongoing battle because my puppies go everywhere with me.
If you were near me, it's a 10 minute inspection to knock out 90% of that list. The tire and wheel possibilities can be knocked out a America's tire with balance while you/they watch the rim. If the weight measurements keep coming out funny, or it takes a LOT of weight - you've found your problem in the wheel or tire. Next is taking it apart to see which is the culpret
If you steel wheels, the wheel could be more likely. If you have off-brand tires, the tire could be more likely.
When you bought the tires, did they "speed balance" the tires? The place where I bought my tires for my Tundra used a machine to speed balance to prevent high speed wobble. have not had any issues with my jeep though. Just a thought. Should be fairly inexpensive.
While you are diagnosing it, I recommend you file a complaint in this highly dangerous issue here..
https://www-odi.nhtsa.dot.gov/ivoq/online.cfm
