Daystar Vs Terraflex Coil spacers
I have a 2 door JK with a Terraflex 2.5 coil lift.
I installed a Terraflex tire carrier and a BFG KM2 315/75R16 tire to the rear.
I installed an ACE stubby bumper to the front. This dropped the front a half inch
Should I go with the Daystar 3/4 coil spacer all around or the Terraflex 1" spacer all around? One costs half the other. Only a 1/4" difference ? One better than the other?
This will put the front 1/4-1/2 higher with the stubby bumper than without a bumper, depending wich brand I go with.
The front I did measure. No bumper to stubby bumper dropped 1/2 inch. The bumper is 100lbs.
The back I did not meaure months ago when I installed the tire carrier and tire, but I know that combo has to be at least 100lbs. I am sure it dipped a little as well. Only fractions of an inch and my wife says she cant see it, but I do.
I am looking also at adding a spacer to my lifted jeep. I have heard some spacers are no true to the stated size. I dont mind buying the more expensive spacer if it is justifiable. Anyone on the forum that has used coil spacers recommend a certain brand and also what are your measurements before and after putting in the spacers?
