Daystar tailgate bumpstops are a joke
Old 09-22-2013, 07:15 AM
jbry311's Avatar
Default Daystar tailgate bumpstops are a joke
Tried installing them this morning and I couldn't get them screwed in all the way, so I used a small amount of force while turning them and then the damn thing rips in half. Would be better if they simply popped in like stock the ones. Waste of $25.
Old 09-22-2013, 07:40 AM
mpullum's Avatar
I had the same problem, but was able to take my time, well at least able to walk away from it 4-5 times and only managed to rip one partially. By then, I knew I would have to rip it I half to even consider taking them back.
Old 09-22-2013, 07:48 AM
Bronco_Bustin's Avatar
If other people have the same problem, I'd call and complain and perhaps their engineers can address the problem so others don't get frustrated too
Old 09-22-2013, 08:04 AM
jbry311's Avatar
Yeah, I'll probably send them an email. Bought them off eBay, so doubt I can get my money back. Oh well. Lesson learned.
Old 09-22-2013, 09:27 AM
hypeiv's Avatar
The daystars have bad reviews all over the net. I extended my oem bump stops with some rubber pipe couplers over a year ago... No problems
https://www.jk-forum.com/forums/modi...9/#post3429740
Old 09-22-2013, 12:23 PM
shabbernigdo's Avatar
I used a pice of radiator hose that just slides snug over the stock bump stop.
Old 09-22-2013, 12:34 PM
Chemlight's Avatar
Ha. Yup. I too was bamboozled. Wasted my money on them a long time ago. Lesson learned. I run the Teraflex hinge and carrier now with extended stock bumpstops. No issues
Sent from grenade range
Old 09-22-2013, 12:50 PM
PG-JKU's Avatar
Thanks for the idea. I used hockey pucks wedged in between for a while, but this idea is better.
Old 09-22-2013, 01:51 PM
Ryan0260's Avatar
Yes, they are a garbage product that need to be pulled. You are better off engineering some as others have mentioned.
Old 09-22-2013, 01:55 PM
jbry311's Avatar
Someone on here put golf balls on the outer rim of the bumpstops and it looked like it worked well. Quick fix for sure. Luckily my stock stops worked on my 285/75's.
Quick Reply: Daystar tailgate bumpstops are a joke
