Daystar rear tire Isolators.
Does anyone have the over all length measurement?
I did not put anything in place of the stock one's when I put a 35 inch spare on and my swing out gate is separating at the welds do to the lack of support.
Thanks for any help.
Do you have it mounted on your stock carrier?
I used those when I mounted my 35 on the stock carrier. I have a 35x12.50-17 mounted on a MT Classic II with 4.5" backspacing. I cut one section off the Daystar tailgate bumpstops and everything is snug. I don't know the exact length though. I hope this helps.
Its not to late Take off your tire before you lose it and order the daystar bump stops and the MBRP reinforcment brackets, all for under 50 bucks , I just installed the brackets and its amazing that the carrier actually holds anything at all. there are eight bolts that have several tiny spot welds on each bolt,at least they could have properly welded the bolts in place. Very secure now as long as the hinges hold up
