Daystar "Hood Wrangler" replacement hood latches...
Old 04-24-2008, 03:23 PM
  #51
Dustoff '68's Avatar
I got rid of the air dam a long time ago and had replaced it with the Skidrow Offroad front skid...now, I'm not saying THAT made a difference, but I have yet to experience the infamous vibrating, possessed and needs an exorcist hood lift you all are talking about, and I have been in all of your situations regarding cross winds, speds of 85 mph+, passing and being passed by killer tractor trailers, etc., et al, ad nauseum....wonder why that is?
Old 04-24-2008, 04:03 PM
  #52
cibach's Avatar
would love to hear how they work
Old 04-24-2008, 04:59 PM
  #53
john98026's Avatar
Originally Posted by mcnaught6
i received my hood wranglers today. haven't installed them yet, and probably won't get to them until the middle of next week, but i'll post on how they work if someone hasn't done so by then.
When did you order? My status still shows Backordered :(
Old 04-24-2008, 06:35 PM
  #54
mcnaught6's Avatar
March 19th.
Old 04-28-2008, 07:36 AM
  #55
digitalex's Avatar
I got mine this past Friday and installed them immediately. They are AWESOME. Completely different feel (much more secure) when latching. They are a nice tight fit and have completely eliminated the shake, rattle and rock of the hood lift. Yesterday was unbelievably windy, so I got a great chance to test them out. It just F&**$ING pisses me off that this isn't standard factory issue. Compared to the upgrade, the factory rubber "dog bones" a obviously a piece of Sh*t.
The directions that come with them SUCK... but then, it isn't rocket science to figure it out. I will add this to make your life a bit easier:
1. When removing the factory latches, you have to pop the plastic bolts that are holding the rubber "dog bone" in. The easiest way to do so, is with a flat head screw driver on the FRONT end of the JK. I would also do the top first. Keep the unit attached to the vehicle helps with leverage.
2. The new metal pins that replace the plastic ones do not slide in very easily. This is a good thing as it adds to the tight fit. Make sure you put the pins in first before applying the glue (see #3) and putting in the screw.
3.. There is a tiny tube of some pretty serious glue that comes with the bolts that attach the new "dog bone". It says to put a drop on both ends before securing. There isn't a lot, and it is easy to run out if you do this wrong. The best way is to only put the blue glue on the screw after the assembly (bolt) is in place. Then tighten. Lastly,
4. Don't go crazy with tightening the screws. You might be tempted to get two screw-drivers and drill away on both sides. If you apply the glue, I don't think there is any reason to do this. The pins are in tight enough for you to get a good snug screw job and the glue will make sure it stays together until well after your lease/car payments are up.
For anyone who wants to know, I ordered my upgrade the day before this thread was started, March 19th. I was told Daystar had two issues. The first obviously was simply demand... they can't make them fast enough. The second was a bad shipment that had to be scrapped and re-done, delaying a lot of us that had ordered a while ago.
Either way, it was completely worth the wait and I would recommend these to ANYONE that drives a Jeep.
Old 04-28-2008, 08:09 AM
  #56
Rubicon Rando's Avatar
looks like i am adding more daystar doo-dads to my heep LOL
Old 04-28-2008, 08:57 AM
  #57
JK-Boy's Avatar
my stock jk one flew off at 160kmh when a semi truck drove the other way, the hood bent :S
im waiting for mine, should be in on wednesday
Old 04-28-2008, 09:30 AM
  #58
^wow... did it actually fly open?
i alwasy tell people "NAH... that would never happen" i guess now i will have to say... "MEH... it's a possiblity" LOL
Old 04-28-2008, 10:13 AM
  #59
WRAITHYJEEP's Avatar
adding that to my list, of wants
Old 04-28-2008, 10:29 AM
  #60
I Drill's Avatar
I've heard good things about this product. I'm planning on picking up a set.
Quick Reply: Daystar "Hood Wrangler" replacement hood latches...
