Daystar "Hood Wrangler" replacement hood latches...
#26
I think they will work great and stop the hood lift. I might get these later down the road but for now I like my fix. I did remove the spring and it did not stop my hood lift. I did put the rubber hose behind my seal and it did not fix my hood lift. Easy, cost effective, works!
https://www.jk-forum.com/forums/jk-write-ups-39/hood-lift-fix-worked-me-30304/
#28
Yes.
Hood Latch Broken
I've done the wire tire mod and it seems to have eliminated the lift, though I haven't been out since in the worst conditions: A strong cross wind on a two lane highway with semi's passing the opposite direction. Those are the absolute scariest moments.
Hood Latch Broken
#30
The only 'update", if you want to call it that, is that these are still about 3 weeks out, per Daystar. I have a set on order and will let you know when they arrive and how they work.
